Some Useful Genesys Configuration Database PL/SQL Scripts...
Some more SQL script stuff. Both should work for MSSQL and Oracle.
-- all installed applications (except GUIs) and their parameters and autostart options
SELECT
	cfg_host.name			AS "Host",
	cfg_host.ip_address			AS "IP",
	cfg_application.name			AS "App",
	cfg_app_tenant.tenant_dbid		AS "Tenant",
	cfg_application.version			AS "Version",
	cfg_server.port				AS "Port",
	cfg_application.work_directory	AS "Path",
	cfg_application.command_line		AS "Command Line",
	cfg_application.cmd_line_args		AS "Arguments",
	CASE cfg_application.auto_restart
		WHEN 1 THEN 'no'
		WHEN 2 THEN 'yes'
		ELSE 'unknown'
	END AS "Auto-Restart",
	cfg_application.startup_timeout	AS "Startup Timeout",
	CASE (
		SELECT LOWER (prop_value)
		FROM cfg_flex_prop
		WHERE	prop_name = 'autostart'
				and object_dbid = cfg_application.dbid
				and object_type = 9)	-- CfgObjectType Application
		WHEN 'true' THEN 'true'
		WHEN 'false' THEN 'false'
		ELSE 'null'
	END 						AS "autostart"
FROM cfg_application
INNER JOIN cfg_app_tenant ON cfg_application.dbid = cfg_app_tenant.app_dbid
INNER JOIN cfg_server ON cfg_application.dbid = cfg_server.app_dbid
INNER JOIN cfg_host ON cfg_server.host_dbid = cfg_host.dbid
-- WHERE cfg_application.type != 8		-- Optional to omit DAPs
ORDER BY "Host", "APP"
The next one is not from me (found it either somewhere here ;D ) or on Genesys Knowledge Base
-- all applications and their connections with ADDP parameters
SELECT
 	hst.name			AS "Host",
	appfrom.name		AS "Application",
	appto.name			AS "Connects To",
	con.conn_protocol		AS "Protocol",
	con.timout_local		AS "Local T/O",
	con.timout_remote		AS "Remote T/O",
	lc.lc_value			AS "Trace Mode"
FROM	cfg_application appfrom
INNER JOIN cfg_app_server con
	ON appfrom.dbid = con.app_dbid
INNER JOIN cfg_application appto
	ON con.app_server_dbid = appto.dbid
INNER JOIN cfg_server srv
	ON srv.app_dbid = appfrom.dbid
INNER JOIN cfg_host hst
	ON srv.host_dbid = hst.dbid
INNER JOIN cfg_locale lc
	ON con.mode_ = lc.lc_subtype
WHERE
	lc.lc_class = 8
	AND lc.lc_type = 30
ORDER BY hst.name, appfrom.name, appto.name
maybe you can start from here, assuming a properly configured Info Mart (works on Oracle, might need some changes for connid and timestamps in sqlserver):
select
to_char(to_date('19700101', 'yyyymmdd') + msf.end_ts / 86400 + cast(dt.label_tz as number)/24,'yyyy-mm-dd hh24:mi:ss') as route_time,
to_char(to_date('19700101', 'yyyymmdd') + msf.end_ts / 86400,'yyyy-mm-dd hh24:mi:ss') as route_time_gmt,
vq.resource_name as virtual_queue,
lpad(trim(to_char(i.media_server_ixn_id, 'XXXXXXXXXXXXXXXX')),16,'0') as connid,
rt.SKILL_EXPRESSION as skill_expression,
ag.resource_name as agent_username,
ag.employee_id as agent_employee_id
from mediation_segment_fact msf
inner join resource_ vq on vq.resource_key = msf.resource_key
inner join interaction_resource_fact irf on irf.interaction_resource_id = msf.TARGET_IXN_RESOURCE_ID
inner join strategy s on s.strategy_key = irf.strategy_key
inner join date_time dt on dt.date_time_key = msf.start_date_time_key
inner join technical_descriptor td on td.technical_descriptor_key = msf.technical_descriptor_key
inner join ROUTING_TARGET rt on rt.ROUTING_TARGET_KEY = irf.routing_target_key
inner join interaction_fact i on i.interaction_id = msf.interaction_id
inner join resource_ ag on ag.resource_key = irf.resource_key
where dt.label_yyyy_mm_dd = '2016-05-01'
and td.technical_result_code = 'DIVERTED'
and td.result_reason_code = 'ANSWEREDBYAGENT'
Thank you - I will give this a try.//
To put some context around this;
A lot of complex Routing can get a bit messy and, sometimes, it’s a good idea to try and find out exactly which Skill/Level the URS used (in the end) on which to base the route for the call. It’s also very useful to troubleshoot your Routing Strategies and Sub-Routines and compare them with actual results.
I knew it would be possible in GI2 but I never got around to finding a definitive answer - I’m hoping this is it!
Thanks again!
…I think this also belongs here - it’s not 100% accurate, but better than nothing for attempting an “offline” conversion between DB Scripting languages (Oracle<>SQL Server):
http://www.sqlines.com/online
Yes! With a little tweaking for SQL Server - and the removal of the provided date constraints, this returns all of the routing/vq/skill/level information, per interaction, for everything on record;
select
dateadd(s, dt.DATE_TIME_KEY, ‘19700101’) as effective_date_timeslice,
vq.resource_name as virtual_queue_used,
rt.SKILL_EXPRESSION as skill_and_skill_level_used,
ag.resource_name as target_agent_username,
ag.employee_id as target_agent_id
where td.technical_result_code = ‘DIVERTED’
and td.result_reason_code = ‘ANSWEREDBYAGENT’
This is getting really interesting… (sad? lol) I see this as “Part 2” of 3 Parts;
For each ConnID:
Part 1 = What did the customer ask for? Answer = collect digits/decode from the IVR
Part 2 = What did the routing do? Answer = collect Skill/Level data from URS
Part 3 = What did the agent confirm? Answer = collect data from DispositionCode/ReasonCode/Softphone/ACW
In this way, it would be possible to check the business and operational effectiveness of all of the (voice) routing, end-to-end. And I’ve not seen that done before…
Is anyone else keeping up with me…? :slight_smile:
Good :slight_smile:
The date constraint was intentional, because I am used to work with very large GIM databases, so if you don’t filter those, well… that’s a looot of wait time and processing on the DBMS.
Note that the requested skills is only possible to extract on GIM when a target to the call is actually selected. This, because URS attach some RTarget* user data just before it issues a RequestRouteCall to T-Server/SIP Server when the option default\report_targets is set to true on URS.
So, to avoid taking wrong data (e.g. calls that Agent did not answer the call, got back to the strategy and then was abandoned), I filtered that query to only get the calls that have been effectively answerer (result_reason_code = ‘ANSWEREDBYAGENT’).
For Part 1, depending on the details, I would think the best way would be to get some reports from Reporting Server on Genesys Administrator [Extension].
For Part 3, maybe a StatServer view with filters could help.
It is also possible to take both information on GIM, given the proper configuration and some tweaking.
IMPORTANT: don’t get too close to GIM. It eats people alive!
lol - I have been swimming in CCA and GIM data for quite some time… I know what you mean… :wink:
