SM Platform - Create AMERICA_ENGLISH index failed.
I only have 1 node
Health:
1560453217 14:13:37 elasticsearch green 1 1 0 0 0 0 0 0 - 100.0%
Nodes:
172.117.179.119 13 92 0 md * DOM-RRCT10
Indices:
what is supposed to come here?
Later when indexer will be able to connect to ES, it will create one.
Yeah.. That is the issue right now. Totally blind on what is Indexer doing
Enviado de meu SM-G9650 usando o Tapatalk
What url you used to check ES status? What is in the esNodes environment variable?
Didn’t find that environment variable. Documentation doesn’t mention it at all.
The URL was the mentioned at docs, http://server:9200/_cluster/health
And it is green
Hmm… try to create it in system variables and restart IIS. Support told me about that variable.
What should be the value?
ā€œhttp://server:9200ā€, if you are using default 9200 port
Willing to kiss you!! The environment variable was there but with a wrong value and there was that port 8080! Fuck sake!
Now, I am getting this at Web logs
2019-06-13T15:16:55.222 Std 09900 WARN SQL Error: SELECT Id FROM partitionTbl WHERE name IN() Incorrect syntax near ')'. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() at System.Data.SqlClient.SqlDataReader.get_MetaData() at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable) at ca.a[a](String A_0, DbParameter[] A_1, Int32 A_2, cb A_3, ICollection`1 A_4, Boolean A_5)
Any idea?
Just for your information, I’m a man :slight_smile: I have Latvian name pronounced as Yanis.
But OK I can accept it, one kiss will not kill me.
I know you are a man hahaha don’t care [emoji23][emoji23][emoji23] you just deserve, an Italian kiss [emoji1787][emoji1787][emoji1787][emoji1787]
Looks like there must be something in the brackets after IN. Will check what is in that partitions table on proper system tommorow. Maybe you are missing some option in SM config? Default workgroup or how it was called there?
Nope, can’t find any missing info.
Saw this at Wireshark while doing a search
}GET /speechminer/api/v1/speakerTypes HTTP/1.1 Host: 172.17.79.19 Accept: application/json, text/plain, */* User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36 Referer: http://172.17.79.19/speechminer/pages/ui/ Accept-Encoding: gzip, deflate Accept-Language: es-ES,es;q=0.9 Cookie: AuthenticationType=Genesys; .ASPXAUTH=13C118D0968CCBA5B7C451722E6D6603629A8E23D9BAFBB18330091D562055DED63DECE7FCA566B56B3C7D98F7CE43713B9BB8903A61A37C7CF2D5EC9CB50FF7AC2CF7D72285FB24B24956DAACF2C87BD8AB832AAFF7C07FF1B43B90B8D358B9CCADEA4A58FE219CA986E34F74A01342; ASP.NET_SessionId=kpr1pf3twgfp32ev4sre3hxg X-Forwarded-For: 172.22.10.240 Cache-Control: max-stale=0 Connection: Keep-Alive X-BlueCoat-Via: 615971f7a9aabed0
HTTP/1.1 200 OK
Cache-Control: no-cache
Pragma: no-cache
Content-Type: application/json; charset=utf-8
Expires: -1
Accept-Ranges: bytes
Server: Microsoft-IIS/8.5
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
Date: Thu, 13 Jun 2019 21:17:51 GMT
Content-Length: 187
ā€œitemsā€: [
ā€œidā€: 1,
ā€œnameā€: ā€œagentā€
ā€œidā€: 2,
ā€œnameā€: ā€œcustomerā€
ā€œhrefā€: ā€œapi/v1/speakertypesā€,
ā€œstatusCodeā€: 0
}GET /speechminer/api/v1/interactions?searchId=11 HTTP/1.1
Host: 172.17.79.19
Accept: application/json, text/plain, /
HTTP/1.1 500 Internal Server Error
Pragma: no-cache
Expires: -1
Content-Length: 123
ā€œstatusCodeā€: -1,
ā€œerrorMessageā€: ā€œThe operation cannot be completed. Please contact your System Administrator.ā€
In the working system I have following request in the Web log:
Running SQL Command: SELECT Id FROM partitionTbl WHERE name IN (N'Users',N'Outbound Users',N'Email Users',N'/ϰa𢠧rupa/janisk')
Here we have listed all four Access Groups I assigned to user which is signing into SM. Seems your user does not have any.
Yes and no.
Was a permissions issue with the Role.
Genesys guy connected yesterday and fixed.
Thanks for the help!
