Route call after disconnect
I did a quick test and all works fine on RP object level. I do now know how you have configured it, but in annex must be the “TServer” section, under this section must be option “after-call-divert-destination” with any valid DN as a value. That’s all.
Hi Kubig,
there i think may be the problem…i didn’t have a TServer section in my Annex tab of my RP, but i have now created one and still no joy :frowning:
i think i am being over ruled by other config ?!?!
really appreciate all of your help
Tambo
Check your logs, if applied you should see it there
Hi Cav, logs don’t show the divert they show call disconnect then call delete.
Would anything in call cleanup etc stop this working ???
Add the option and see what happens in the logs.
rookie mistake…sorry lads
SIP server 8.1.000.86 is the correct version for this to work but we’re on 8.1.000.81 ?!?!?!?
going to upgrade !
cheers for all your help
Tambo
