According to what I’ve understood, I must use the delivercall to gvp to assign audio resources; if I didn’t do so, the play application doesn’t works. If I use the delivercall for gvp resource recall, the only way I know to efficiently exit from gvp is using the play&exit application (a studio app called through a play app ird block). This flow generates the eventabandoned.
can you post a screenshot of your IRD and GVP apps?
No problem for ird app, but I haven’t studio apps sources. Can I reverse compile it from somewhere ? (think they’re deployed in IPCMs, somewhere).
Keep in mind that in the “out” app there’s a “oncallabandoned” declaration, to use the eventabandoned in order to recall the “abb_out” app.
http://web.tiscali.it/modifiche/out.png
http://web.tiscali.it/modifiche/out_abb.png
lol, will send you a PM mate
