Genesys & Blaster Campaigns
Well I’ve tried all these settings and some more based on what I’ve read in the documentation and I still can’t seem to get this blaster campaign to run any faster then it does… I ended up having to create an AgentID on my Avaya switch with a dummy skill assigned to it. And I have to log that agentID into GAD and go ready in order to have that particular campaign call even at a pace of 100/hour. It’s still unacceptable, since I have about 2000 records a day to call virtually - and I’m not getting through them currently… Following are the settings I currently have in my CampaignGroup:
[OCServer]
pa-selfcheck-awt-threshold=5
pa-selfcheck-bf-threshold=90
pa-selfcheck-interval=60
pa-selfcheck-odr-threshold=100
predictive_algorithm=advanced_small_group
predictive_hit_ratio=10
predictive_hot_start=true
predictive_inbound_call_duration=10
predictive_inbound_rate=0
predictive_outbound_call_duration=10
time-to-ready-tolerance=1
Any suggestions on these settings would be appreciated.
Already told you…add more agents…1 isn’t enought
Just to stress it, if you are expecting Genesys to run blaster campaigns, you have gone for the very wrong choice, mate.
Fra
Unless you do a Genesys OCS integration with GVP :slight_smile:
Or do what I told you to do…
