but if an agent registers dynamically while our application is running and it doesn’t work the
first time - it wouldn’t be ok for the customer.
??? ??? As soon as T-server starts up, your application requests DNs registration to it; after 0.11 secs your application will already have got back a positive registration. Why woulnd’t it work if an agent dinamically registers ??? The issue here is on startup..
If you have another enviroment where 7.2 T-server acts different, check the version and report back the logs.
thanks again for your answer.
If it would be possible to get Genesys 7.2 support of the “working customer installation” we
would have done it. But this working Genesys 7.2 installation is not from us - it’s from a
third party company and we don’t have access to this Genesys 7.2 T-Server. It’s maintained by
a third party company and there are some instances between us and them … This Genesys 7.2
T-Server is only a third party component in a running system from us.
As you can see in the following trace lines it is possible that there are problems if an operator agent
registers dynamically because for such a DN in our functionality TAgentLogin is necessary. This TAgentLogin
can’t be possible confirmed after EventDNOutOfService. Sure, there’s also an EventDNBackInService but
too late.
So we want to go sure if we’ve to change our application with Genesys 7.2 because there comes
perhaps always EventRegistered, EventDNOutOfService and EventDNBackInService or if we perhaps
can avoid EventDNOutOfService - the goal is if possible not to change our application.
13:35:24.510 Trc 04541 RequestRegisterAddress received from 528 (0002 Fozzie MOS Genesys 5.00)
message RequestRegisterAddress
AttributeThisDN ‘3023’
AttributeRegisterMode 0
AttributeControlMode 0
AttributeAddressType 0 (Unknown)
AttributeReferenceID 41
map <dn,conf>: find (3023): Ok
[ 4 - ] DN: ‘3023’ Links assigned
13:35:24.510 Trc 20006 Number of seat licenses in use 1 out of 20 available
(tservice_proc) AddressType set to 1 for 3023
(tservice_proc) ControlMode set to 1 for 3023
** ts7.2.008.01[4] <> ** 13:35:24.5100
08 00 00 1B 08 02 00 27 64 96 1C 13 91 A1 10 02 01 0B 02 01 C4 40 08 96 49 05 83 33 30 32 B3
=== parsed message ===
prot_discr = 8
CRV = 27
MsgType = 100 (REGISTER)
Facility: serv_discr = 17(q932_suppl) fac_ie = component_tag = A1(INVOKE)
invoke_id tag: 02, value = 11
operation tag: 02, value = 196(Domain_Control)
params = q931_tag = 40
list =
Domain: type = 3(Extension) address = [4] 33 30 32 33 ‘3023’
@13:35:24.5100 [0] 7.2.008.01 send_to_client: message EventRegistered
AttributeEventSequenceNumber 000000000000002f
AttributeCustomerID ‘Resources’
AttributeTimeinuSecs 510000
AttributeTimeinSecs 1161344124 (13:35:24)
AttributeAddressType 1 (DN)
AttributeExtensions [37] 00 02 01 00..
‘AgentStatus’ 0
‘status’ 128
13:35:24.510 Trc 04542 EventRegistered sent to 528 (0002 Fozzie MOS Genesys 5.00) @13:35:24.5100 [0] 7.2.008.01 distribute_event: message EventDNOutOfService
AttributeEventSequenceNumber 0000000000000030
AttributeExtensions [17] 00 01 01 00..
‘status’ 128
AttributeThisDN ‘3023’ @13:35:24.5100 [ISCC] Debug: Translate: ‘’ → ‘’; result 1 ()
13:35:24.510 Trc 04542 EventDNOutOfService sent to 528 (0002 Fozzie MOS Genesys 5.00)
13:35:24.510 Trc 04541 RequestAgentLogin received from 528 (0002 Fozzie MOS Genesys 5.00)
message RequestAgentLogin
AttributeAgentID ‘52100’
AttributeAgentWorkMode 0 (Unknown)
AttributeReferenceID 42 @13:35:24.5100 [0] 7.2.008.01 send_to_client: message EventError
(Out of service)
AttributeEventSequenceNumber 0000000000000031
AttributeErrorCode 58
AttributeErrorMessage ‘Invalid request: originator is not monitored’
13:35:24.510 Int 04545 Interaction message “EventError” sent to 528 (“Fozzie MOS Genesys 5.00”)
13:35:24.510 Trc 04542 EventError sent to 528 (0002 Fozzie MOS Genesys 5.00)
13:35:24.542 Trc 04541 RequestAgentLogout received from 528 (0002 Fozzie MOS Genesys 5.00)
message RequestAgentLogout
AttributeReferenceID 43 @13:35:24.5420 [0] 7.2.008.01 send_to_client: message EventError
(Out of service)
AttributeEventSequenceNumber 0000000000000032
AttributeTimeinuSecs 542000
13:35:24.542 Int 04545 Interaction message “EventError” sent to 528 (“Fozzie MOS Genesys 5.00”)
13:35:24.542 Trc 04542 EventError sent to 528 (0002 Fozzie MOS Genesys 5.00)
** link[4] <> ** 13:35:24.5420
08 02 80 27 62 96 1C 06 91 A2 03 02 01 0B
prot_discr = 8
CRV = 8027
MsgType = 98 (FACILITY)
I’ve understood you goal, anyway the issue you are facing occurs only on TServer startup: your application sends a RequestAgentLogin right away, while TServer is still registering DNs and assigning them to the configured links.
