Dialogic D120JCTNew VTO ports config help needed
Telling me the cabling colours is a bit misleading, since they could be anything really perhaps trial and error would help you?
Again, I would also check your strategies and perhaps your default port/route (if you have one, remove it temporarily as you redial the 2 faulty ports, then reapply it after testing…)
There is not much else I can advise, without getting my hands dirty! :slight_smile:
Tony
Tony,
Many thanks for all your help, as i have managed to get them all working.
The cables were wrong and they were plugged incorrectly so we are all up and running now many thanks.
Glad to have helped!
Tony
